Eibach front/rear ARB - what's the general opinion...
No opinions on these then?
I think its only the front that eibach make for the fabia, and its 1mm thicker than standard so most dont bother
vRS is 20mm eibach is 22mm so rules of thumb 20x20x20x20 = 160000 22x22x22x22 = 234256
So 234256/160000 = 1.4641 So if its all made from the same matterial the eibach front is 46% stiffer.
The biggest effect of a stiffer front sway bar on the tubby front end of the VRS will probably be to increase understeer which is something you dont really want. I am not sure what it would do in conjunction with a RARB but for the amount of effort needed to fit it, it would seem a bit of a thankless task.
