ARB Knocking
Hi People
My rear ARB is knocking on the exhaust quite badly. Any one had this? if so how did you stop it?
Phil
The Fabia doesn't have a RARB as standard, and if it's had one fitted, it should be on the far side of the suspension beam from the exhaust. Is it not that your exhaust's loose?
i know that thay don't have one as standard I have had one fitted.
It is on coil overs and there it is lowerd it is knocking a little. Was just wondering if anyone else had this?
I can see where it is knocking because it has warn some over the covering.
I see you have a Jabba rear ARB. Is it the rear silencer which is hitting the ARB?
yea it is. It is because the car is lowerd so much on the coilovers.
No one else had this problem?
