Brake upgrade
Hi Fellas
i have a y reg fabia tdi 100pd however i have aqquired some vrs front calipers and discs and was wondering what i have to do to fit them
i was advised that i would possible need different hubs
any help required
cheers
folks
Yeah, they wont fit, and you will need vRS hubs. Sorry.
Not sure if you could fit any other VAG hubs.
HTH. Dave
Right Does anyone no of any vrs hubs or what other vag cars have vrs hubs
cheers guys really need your help hear need to get these brakes on the standard ones with 170ish hp and nearly 280lbtf are getting scarey
cheers guys
shaun
Speak to Devonutopia or Lummox about whats needed. I'm guessign hub from vRS, Ibiza PD130 upwards or Polo PD130 upwards.
I think that the "search" function using "upgrade brakes" or something like that should provide info for you. Or if that is not enough for you hop across to seatcupra.net and check under Ibiza MK4 facts sub-forum - its certainly covered there and its a 100PD that initially was asking about changing to the "other hub" with its options.
Edited by rum4mo
