EGR fault on a 1.4 16v fabia
A mate of mine has asked my to post this up as for some reason he cant register on here not sure why:rolleyes: but anyway he has a 1.4 16v fabia which has an EGR problem, he has replaced it but it still comes up with a fault on VCDS saying it has insurficent flow.
Any ideas anyone?? :)
prolly needs to clean out the pipework, fairly straightforward job, plenty of info if you do a search.
That was done when the new EGR was fitted any other ideas??????
Has the pipe work been properly cleaned?
Was the gasket fitted the right way around?
Has basic setting been carried out?
hi.i have the same trouble my friend.the problem is that the first catalyst,is metal.this catalyst is always braking into very very little pieces.these pieces are making problems to the egr.i have removed the first catalyst and new egr and for many many kilometers i dont have any trouble.
