Will this cable work ok with my Fabia?
It sure will work with the Fabia. In fact its the same one i have. It will enable you to scan indivdual controllers and erase fault codes.
Not too sure about clearing airbag light though. I never scan the airbag module. I read recently about clearing airbag fault and if the car has been pranged the crash data is stored in the module.
HTH
Edited by Guest
No need to quote original post.
Cool, thanks. Car hasn't been in a crash, I replaced the steering wheel with a 3 spoke leather one and airbag. Says on that eBay ad that it clears airbag codes, so should do the job. I just wanted to check it was compatible with my car. Thanks!
Edited by DGW
No need to quote previous post.
I'd be careful playing around with airbags as they can go pop, but I suppose you already know this.
Iirc vag com doesn't scan them without asking you first for this very reason.
Edit.......Although this issue may have been adressed in later versions
Edited by fatty5000
  • 4 months later...
Imperator, did you get the cable in the end? Im thinking of getting one myself just to read codes when engine management lights come on so I know if its urgent or not.:rofl:
Also link isnt working anymore, do you have the sellers ID?
Ta,
Mike
