Sat Nav?
Recommended Posts
The electrics are easy to sort out as all you need are the speed sensor wire (GALA), a reverse wire sensor (from reversing lights) & a GPS ariel.
You can then go to the local VW/Skoda dealer & look on ETKA (or speak to a member who has it) & pull off the part numbers for the wiring plugs which are easily fitted.
The Sat nav units have the wiring pin locations on a sticker on the unit so it is quite simple. (I know as I have just done it in a Touran).
The only question is do you have space for a double DIN unit ??
PS Check E-BAy as you can pick them up from Germany for between
Link to comment
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
