Door light problem!!!!!!
not had many issue with my car since having ownership of it, but they have started to come out, one of first was a rattle in the engine bay which turned out to be a loose bolt that holds the metal pipe from the turbo down to the intercooler!
now thats sorted the door light has come on while driving back from wembley, checked all doors and shut them all then it went out:confused: now when you go over bumps or put the boost on it comes on and off even tho all the doors are shut:confused::confused::confused::confused::confused:
anyone had this or experienced this or any help to solve this:orb_sad:
Water ingress into one of the doors light be causing this. Or is could be (and this could be more likely) is a dry joint for one of the micro-switches in the lock mechanism. Essentially the car thinks the door is open. Check that when you lock the car it actually locks all the doors...
