Fitting a set of KW's V3 myself
After being let down by 2 mechanics I decided to fit the KWs V3 myself. Any tips or pics. What else do I need to fit them.
I cannt see the rear being an issue but the front might be a bit more difficult.
i found the front fairly easy just takes time mate. the rear is tricky due to the tools youll need.
replied to pm;-)
hope it helps
After youv finished fitting you will defo need camber and caster adjusted. You cannot do this at side of road so would advise a specialist garage, cost will be about £50-100. If you dont and try by sight alone you will have spent all that money for nothing. Handling is nothing if its not set up correctly.
Pro Grip Falkirk, Star performance kirkaldy, ccs autotyres sighthill edinburg, are the only one i know that have the most upto date calibrated ramps (not ure kwikfit set up but professional 10-20k worth)
Do it properly and enjoy:thumbup:
