Where is the PAS fluid intake
Hi..
I have a fabia 1.9tDi and having problems with the PAS.
Took it to the garage and they said that the steering rack was leeking and needed a new one.
To cut this short I did the job myself and replaced the sensor (as it broke). Then I went to top up the PAS fluid and can't find the intake.
The book said it is near the battery, took the battery out and still can't find it.
Searching here, found a topic about it being on the left under the fog lamp.. Still can't find it..
My steering is still heavy and the warning lamp is still on...
Can someone please help me...
:confused:
It's UNDER the battery IIRC...
:rolleyes:
taken battey out and can't find it...
Also ; do i need to reset dodes or anything
Remove battery tray as well - bingo!
Indeed! No point removing the battery if you don't remove what the battery was inside. :D
