problems???
Hi' I wonder if any of you wizards out there can help me with a problem i have with my T reg 1999 octavia estate. There does not appear to be any leaks anywhere, but i have a damp patch under the front passenger seat, at times its a puddle even though it has not been raining, just wondering if anyone else has this problem.
thanks bill
Weclome to Briskoda
Davy
Hello and Welcome.
Hello & welcome, Not sure where the rear wash tube is routed, but perhaps that is leaking. It is better to post your problems in the Octavia I section.
Welcome :)
Hi
May sound daft , but are you using the air con?
Also check the rad fan switch
Usually located passenger side at the bottom of the rad
Just a couple of thoughts
Welcome to the forum
Sarah
welcome
Dislodged or blocked drain on the air conditioning?
