Small Idle problem
Hi
I have just recently started having a small problem with idling when stationary. My revs will fall a very small amount and then you hear the engine pick up again, and then they fall again..... and so on.
Is there anything I can clean out to fix this? It has just been serviced with the fuel filter and oil changed.
Try a throttle body clean? There's plenty of posts on it and it's easy to do. I did mine this weekend and I'm by no means a mechanic so if I can … :D It seems to have settled the idling but I guess only time will tell. Just don't disconnect the electric connection and you shouldn't have to reset the throttle alignment
Good luck :thumbup:
could be the MAF as well. you can check it by disconnecting the Maf connector and if it runs smoother then MAF needs a clean or replacing. HTH
