Problems,problems and more problems
And even more of the never ending problems with my 1.4 MPI 8V .First of I can`t find the PAS steering angle sensor`s code for the early fabia models and don`t know if the newer ones will work (and what are the factory codes for those as well) and to make matters worse,it looks like it can be bought only from the dealer and there is no way that I`ll pay 100 euros (where here the average worker gets 300 euros/month) for a piece of junk that will last only about 1 year from new ,fom the dealer :mad: ...I`m getting an impression that vw group cars suck in general, not to mention the dealer`s attitude problems when there was once when they wanted to charge me money for some info about the price of some parts... I`ve also unplugged the sensor from the pump because it tried to kill the pump,the oncoming traffic and me... Then, water leeks from the radiator, enough to resemble a lake and to attract the nearby frogs under the car, so far I`ve managed to find out where it leeks, not a big problem but definitely kills some brain cells and will make you`re hand smell like rotten condoms, radiator drain valve or cap or whatever it is doesen`t close properly... And then,lambda sensor screw ups, the car strats on an insant when the engine is cold but not when its warm, missfires pretty badly when it`s warmed up, however the spark plugs are dry and have white burning marks wich should be ok...when I step on it will eat half a tank in an instant but when driving like 90 yr old the same amont of fuel will last about 3 or 5 days depending on city traffic ... Then funny sounds from the front suspensions I guess when going over bumps , sounds like they are on air, sounds exactly the same as those old bicycle air suspension forks when they let out the air when they are pressed hard,makes a fast "HSsss" sound... I need some help, at least for seting the car on fire
Welcone to the club, yet another member who have discovered the Fabia 1.4 MPI as the most efficient vaccine with a life-long effect ever made against any and all VAG corporation products!
:mad:
