Skoda Fabia 2002, 1.9 SDI, Vag-com AUTO-TEST
I tested an Skoda Fabia 1,9 SDI, registered first in 12/2002 in Vienna Austria and has a total of 148.000 Km by now.
After doing an auto-test in VAG-COM the result came this way:
VAG-COM Version: Release 311.2-N
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 038 906 012 GE
Component: 1,9l R4 EDC 0000SG 3924
Coding: 00002
Shop #: WSC 13765
TMBJF46Y133660428 SKZ7Z0B1601351
5 Faults Found:
17569 - Manifold Temp Sensor (G72): Open or Short to Plus
P1161 - 35-00 - -
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
17660 - Cold Start Injector (N108) Open or Short to Ground
P1252 - 35-10 - - - Intermittent
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-10 - - - Intermittent
19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
P3101 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 G
Component: ABS 5.7 FRONT V20
Coding: 00044
Shop #: WSC 13765
No fault code found.
Address 08 -------------------------------------------------------
Controller: 6Y0 820 045
Component: Klimaanlage X0830
5 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-10 - Open or Short to B+ - Intermittent
41-10 - Blocked or No Voltage - Intermittent
29-10 - Short to Ground - Intermittent
28-10 - Short to B+ - Intermittent
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 09226
Shop #: WSC 13765
12 Faults Found:
01598 - Drive Battery Voltage
27-10 - Implausible Signal - Intermittent
01309 - Power Steering Control Module (J500)
49-00 - No Communications
01321 - Control Module for Airbags (J234)
49-10 - No Communications - Intermittent
01316 - ABS Control Module
00899 - Fuse for Wiper Motor (S128)
37-10 - Faulty - Intermittent
00966 - Fuse for Blinkers (S151)
00900 - Fuse for Signal Horn (S194)
00969 - Fuse for Heated Rear Window (S41)
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
01314 - Engine Control Module
07-00 - Signal to Low
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6Y1 919 880 D
Component: KOMBIINSTRUMENT VDO V12
Coding: 16142
Shop #: WSC 06225
2 Faults Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 34 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 13765
6 Faults Found:
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 2S Komfortgerát 0002
Coding: 00067
Shop #: WSC 13765
7 Faults Found:
01031 - Central Locking Key Switch: Driver Side: Unlock
27-00 - Implausible Signal
01330 - Central Control Module for Central Convenience (J393)
53-00 - Supply Voltage Too Low
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
01331 - Door Control Module: Driver Side (J386)
53-10 - Supply Voltage Too Low - Intermittent
01358 - Internal Central Locking Switch: Driver Side (E150)
01332 - Door Control Module: Passenger Side (J387)
End -------------------------------------------------------
I can't say what's really wrong, because i don't know the descriptions very well..Is anything serios??
Thank you in advance....
:eek: Ummm, does anything work on this car? :confused: For starters, it seems the key isn't coded to the car so it will not start!
OMG! It would have been quicker for VAG-COM to check what WAS working rather than the other way round.
Got lots of issues to work on there.
Most are pretty self explanatory!
Get it to a garage sharpish... or to a scrapyard!
Phil
Amazing might be but the car starts...
I was going to buy that car but...i just was, cause i did't ..
Thanks for the answears...
Now i found another one that auto-testing it found very few faults..one of them beying a steering problem..And i could tell that by my self because the weel was stiff...
I bought this car an now i am trying to fix the steering. I know that the pump is under the battery, but the sensor?? i tryied to find some manuals, or some pictures of the steering on my Fabia but with no succes...
Can anyone tell me how to do a check, maybe some pictures or a web address?? i searched all night...
