Door Locks
When sat in car with ignition on i pull catch to open my door and all the doors are opening, previously i had to pull the lever once for my door to open and twice for all the doors any ideas what might be the cause or should i go to dealers let them check on vagcom if it would show a fault:finger:
1) Why the finger?
2) Dealers dont use VAGCOM
3) Is single door opening working?
didnt mean to put finger thought it was grumpy face . when i take key out of ignition drivers door lock opens only also if using remote one press opens drivers door
Right, so what are you expecting it to do?
Sounds like your car is coded for single door opening and drive away locking.
car does lock on driving away i was querying why after two years the lock was operating in a different manner ie not two pulls for all doors now only one. thanks for your input
