rear door help !!!
Evening everyone !
My octy seems to have sprung a problem on me today that im not sure how to sort.
The rear passenger door doesnt seem to want to unlock, all other doors an the boot are fine just this one.
Ive tried allsorts, problem is i cant remove the door panel to look inside as i cant get it open !!
Also ive just noticed that the arming light for the alarm and imobiliser on the drivers door isnt coming on and i guess this is down to the computer not recognizing the back door being locked?
Has anyone got any clues how i can sort this ???
Hope to hear some good pointers soon, cheers !
if you open the front door on that side can you not get access to the rear door hinges, either to remove the rear door and sort it that way, or to get access to the rear door card?
its likely to be a problem with the wires going into the rear door in the rubber connector going across the door gap, or the locking motor in the door itself.
if you can get access to the inner door, you will find the issue a lot easier obviously.
I think dealers have some secret method of getting the rear doors open when this happens.
Maybe someone on here knows, as I've seen a thread on this before.
All I know is that it's possible without destroying the door card, which is not always the case!
