wing mirror casing
Hi all. Hope someone can help me with this - my drivers side wing mirror has been broken, but it's only the metallic black casing that's been damaged, the electrics still work fine, and it still folds in and out ok. Can i get away with just replacing the casing, or will it need an entire new wing mirror?
Should be able to get away with just the casing. I have a busted manual mirror if you want it. The main casing is fine, but the little panel underneath with 2 screws in is broken. You're welcome to it for cost of postage. Casing is white though so will need respraying. :)
Just the casing needed then.
If the other stuff isnt broken... dont fix it.
Or get a local dealed or garage to check it out, on the off chance somthing else is broken.
