Diagnostics on a Mitsubishi Spacestar (2000)
My wife has a 2000 Mitsubishi Spacestar 1.3L 200 reg, which throws up the Engine Management light quite often.
It has an OBDII port, but I think it has a different pin configuration than the VAG group cars, and reading up on it, it needs MUTII protocol to scan it. I presume a different lead is required?
Can anyone advise?
search google for ELM327 i think, they're a universal diagnostic device that can read most protocols.
With a 2000 model year you are a bit stuck. Don't think ELM327 will help.
You will need a 1.3u cable and EvoScan software (or find somewhere that has it - e.g. independent garage that services Evo's and FTO's).
Cable and software about £70:
Mitsubishi OBDII DataLogger - EvoScan
Thanks for that guys. I had found the EVOScan software link, buy couldn't figure out which cable I would need.
