CD Compatability
Ive got an 2004 Fabia vRS. Does anyone what type of blank cd's work with the stock head unit?
Cheers,
All copies should work fine on the headunit.
no blank ones will work with it, try burning some music to a CD for better results.
HTH.
HTH.
Maybe he's the quiet and silent type.:)
maybe so, in that case why would you be putting CD's into the stereo though?
At times it's better than listening to Radio 1! :)
quite so, that sarah cox is dreadful.
i find i cant turn the treble down enough when she is on, so i have to use the other option being the off button :rofl:
HTH.
Thanks for the tips!
always here to help :thumbup:
Anything is better than Radio 1.
Are you trying to play anything other than WMA files? It doesn't work with anything other than standard audio tracks eg. MP3 etc. don't work.
If it's just a copy disc you're making then set your burner to a slow setting and avoid cheap 'white label' discs. I use Kodak from Tesco's - cheap, but good.
Ok il try a branded make, burning WMA format. cheers for the help.
