Light Problem
I went to lock my car before with the key fob but instead of the passenger door light flashing it is now on constant.
Is there a way of curing it?
Could you have accidentally double-clicked or hit the button on the door? The sequence of lights tell you whether the internal sensor is active or not. If the indicators don't flash, one of the doors hasn't been closed properly.
Jo
my passenger door light does not flash.. it is always constant
Mine is flashing...
Hi all
I checked my manual this morning when I got to work. If the internal protection is active, the light should go out then flash slowly. The manual says that if it stays on constant, it does inidcate a fault with either the central locking or alarm system and it needs to be checked.
I should add that this refers to cars with an alarm and remote central locking.
Thanks for the reply Jo. I went out later and opened all the doors and shut them again and everything is back to normal.
:) Good to hear that.
