Dance stereo - no sound at all
I fiddled with the settings and now I have no sound at all from the speakers, no matter if it's CD, stereo or AUX. Any ideas what I have turned on or off?
Maybe FADER or front-rear setting?
Not sure what happened but after I left the car for a few hours and then came back and tried it, it worked immediately. Feel a bit stupid I don't know why.......
What does "FADER" do?
(Thanks for your suggestion).
I'm not very happy with the BASS while I'm here. There's A LOT of vibration. The highs are far too high as well. Right now I'm have the bass at -5, medium at +5 and highs at -5. Seems impossible to get a good sound actually. How do other people find it? Perhaps something wrong with mine?
u not the only person who has had this problem.. i have had it happen twice
but then it just starts working after a while... it may just happen that the system gets heated up after playing music for a longer period of time..
fader
this helps in adjusting the sound volume .... u can set how much volume can be distributed to the right left or even front and rear speakers......
it is a real handy tool......it can also help a lot if certain speakers do not throw proper base.
I had the same problem 3 or 4 times in the past. Usually when pressed the track jump too fast to skip many tracks on an mp3 cd. I had to remove the ignition key ro reset the fault. I think it's a firmware problem, now I use the arrow keys slower and no problem at any time.
I have an mp3 cd in the slot. I got in the car and the wife had been listening to the radio. Tonight, I pressed cd to get my music back on as I have done many times after my wife has been driving. This time it said error and spat cd out. put it back in 3 times and still said error and kept spitting the cd out. Switched off radio, then back on, inserted cd and it was fine.
Stupid thing!!!:confused:
i felt the same after two days of having the stereo on volume 20 the two tweeters in the front blew - every now and then they rattle as if they are trying to work. you can replace them with fli 6 integreator speakers. if not and you do want to replace the speaker size is 6 - 6.5 as they are fitted with spacers. i had to get my dealer to take my door cards off to find that out . . .
My Fabia 80 TDI Sport had the same problem on 3 occasions, always been when radio is on, it just fades out, CD works ok though if I change, but go back to radio and nothing.
As others have said, get back in the car a few hours later and bingo every things fine.
Only fault 4 months.
