Erasing error codes
I bought a cable to run diagnostics, i repaired the fault and need to wipe the code, does anybody know of a program that can erase error codes... and is free?
Trial version of VAG-COM.
We have a forum called 'VAG-COM & Diagnostics', so I'll give you three guesses! ;):D
I've tried using vag-com and when i try to erase the error codes it says i have to register my copy
I think that's if you try an auto-scan. If you know what bit you replaced, you can take a punt on which module the fault's on, in which case you should be able to do a manual scan / erase on just that module!
HTH :)
Will try tomorrow and see if i can get it to work
