Passenger mirror angles down when reversing ??
If it is as in the octavia, you will need to have the electrically adjusted seats with memory. Only if this option is in the car, the passenger mirror will angle down when reversing.
Thats probably why I couldn't get it to work on my Octavia Vrs then - no electric seats
That is right. Not even programmable with VCDS.
If it was not for work why option in the MFD panel mine is a SE and it works
As anyone were repair that the brightness of panel is not ajustable by the switch to lower light down ???????????????????
You say it works on your SE ?
Do you have extra options above normal SE spec ? such as heated electric seats or auto-dipping exterior mirrors ?
If not then would you please tell me what combination of MFD programming and mirror switch position does this ? many thanks in advance
my car don´t have extras radio bolero but doesn´t have as heated electric seats or auto-dipping exterior mirrors, when i buy it that function doen´t work so i call skoda dealer and nothing, so i call skoda stand local well and it works since today i only have the car 20 days, now say to me does your car brightness panel work mine is always higher and don´t lower in switch next light controls does your car wor fine or is equally ?????
please tell me thank in advance,
taxi!!
:D
taxi!!
...you forgot your coat sir....and please close the door on your way out !:rofl:
Sorry I do not fully understand :confused: - did Skoda have to fix it ? If so what did they do ?
Yes my dimmer control (next to the headlight level adjuster and near the headlight switch) works fine. :thumbup:
