Heated Rear Window turns off radio
I have at long last fitted a cd/radio to my 1997 Felicia, however the heated rear window now turns off the radio. I have taken the power and earth from the white connector under the dash near the centre, the earth I assumed was the black lead. At this point I have both power leads to the radio as constant power. If any one could please advise what I have done wrong. Thanks
which white connector have you taken the black wire from?? the earth in the radio loom is brown on the felicia
it's best not to 'assume' things when wiring things up
Tom, Thank you, this has now resolved the problem and I can now have music and use the HRW. Ian
