Electric Mirrors Retrofit
Hi,
I've got an 2006 1.2 Sport which sadly came with manual mirrors and no rear speakers. I've added OEM rear speakers using the skoda kit, fitted just about every OEM accessory I could find on eBay including the MFD, but I'm stuck with the annoying manual mirrors. Does anyone know if its possible to change them for electric?
So far using the search function i've discovered that the door wiring loom seemed to change occassionally depending on model and year. I don't have the red lights in my door, but i do have electric windows, so I assume I have a more basic loom. Is it just a straight swap with the mirrors, loom and switch from a scrapped car, or would the convenience module etc be differerent? My fuse box seems pretty basic too. I have no spare switched lives in there, and only 2 spare permanent lives. I'm assuming the sport had very basic wiring to cut cost.
Does anyone know? I'm guessing this mod might be too expensive to be practical.
It is possible Ross (Lummox) will have appropriate bits from my old estate or vRS that you could use, but not sure :)
Cheers for the reply. That sounds promising. Is it a big job? I've not actually had the door cards off on the fabia yet, so not sure what the wiring is like under there. Is any dash trim going to have to come off for the wiring?
