alloy wheel enquiry
Just send them an email if they fit the fabia, Wolfrace are not an expensive rim so price seems just average to me! But not expensive.
Pay the extra get some decent rubber, as i always say ye spend money looking good might as well spend it to be safe or save some money from accidents.
If you like them go for it, your the 1 who has to look at them everyday, if you think they look the dogs then we are all happy for ya, me i would go 16 or 17 set her off nicley.
Good luck whatever you decide. Remember always buy good rubbers it can save you money!!!!!!!!!
i was told that if i went 16" or 17" on standard setup of my comfort fabia it would offset the speedo and be to big unless i changed my suspension is that true? wouldnt 16-17" be to big for the arches?
ryan
I'm sure you understand that the aim when changing wheel size is to keep the overall diameter as close as possible.
In your case, the diameter is 23.47" and there are loads of tyre size calculators online. If you swap your 14" wheels out for a stock Fabia vRS rim (with 205/50/16) it goes up to 24.07 which is about the limit of how much you want to change by (+/-2.5%).
If you go for a 17" wheel with a 215/40/17 tyre it only changes by 1.3% to 23.77".
Your choice of 195/55/15 on a 15" rim actually would make your speedo under-read by almost 3.4% which is more than I'd be happy with.
Have a play on here TYRESAVE: Tyre Size Calculator
I've had 215/40/17's on my fabia and they didn't rub. The biggest problem with dropping the tyre sidewall height on almost all cars is that the arches look REALLY empty even though in theory the wheel and tyre are the same size. You end up having to drop the suspension to make it look right.
Cheers wja96 im sorta with ya ill have a look at the site
ryan
It is a little bit complicated, but basically, what you add to the wheel, you have to knock off the height of the tyre.
Bigger wheels = lower profile tyres. The overall size of the wheel and tyre package has to be roughly the same as what you started with (+/-2.5%) otherwise your speedo will read incorrectly.
If however you change them to vRS rims with the CORRECT tyre size of 205/45/16, the diameter is 23.26, which is pretty much spot on (-0.84% difference).
Edited by RobClubley
Removed a small swear :o)
Yeah i went Vrs Rims on my sdi faby! looks much better and handles nicer too. Overall havent really lost or gained anything think its about -0.84% which i guess is basically neglectable.
Indeed. Thanks for posting the correct info.
so would this + or - minus be the positive or negative effect on your speedo? thanks
looking at getting 15" maybe 16" for my fabia in the new year
I believe +% reduce indicated speed, -% increase indicated speed as they increase or decrease the distance travelled per revolution of the wheel.
