Brake Fluid
Time for another brake fluid change, so question is which of the following should I use? Please don't suggest others that don't fit in with the list unless you can buy them from halfords.
- VAG DOT 4 Fluid from dealer
- Halfords DOT 5.1 Fluid
- Halfords DOT 4 (ESP)
Currently the car has whichever DOT5.1 that JKM used.
Is the halfords dot 5.1 any better than the VAG DOT4 fluid?
Ta
DOT 5.1 is mandatory :cool:
I would go for Skoda brake fluid :).
skoda use the VAG brake fluid which is available at any VAG dealer
I know skoda use VAG brake fluid and I know it's available from my local dealer, but I also know it's DOT4 which is what the book says to use.
Be interesting to hear from Shifty or anyone else who ran a heavily improved car and see if the 5.1 made a difference. I'll go along at some point and ask about the trade price.
Edited by cheezemonkhai
Dot 5.1, even Halfords sell it if you need a price check, Ive supplied it before to the local Skoda dealer to put in
DOT 5.1 (which like DOT4 is glycol based) is OK to put it and does make a difference to braking performance. The performance is as good as many racing fluids.
UNDER NO CIRCUMSTANCES SHOULD DOT 5 (which is silicone based) be used in a car that has had DOT4 (glycol based) in. The two interact and form a gummy residue.
Will see how much it is on trade :) Ta
Well £5 a bottle on trade, so ho wmuch does an octy II require for a full change? 2 Litres sound about right?
Whenever I've done this I always found I needed much more than I expected. I'd have 4 litres to hand maybe if getting to Halfords without any brakes is going to be difficult :)
No way, where do you stuff that much? I saw the figures once, can't remember if it is 2.2 or 1.2 liters. Probably 1.2, but I'd buy 2 just in case.
Dealer says they use 2L to bleed and full change so I've gone and got 2 * 1L bottles and 1 250ml bottle.
Should do the job just fine and i'd rather have a touch too much pushed through than not enough :)
4L sounds excessive mind as you'd be pushing an entire system of clean fluid through and out.
AHA:
Brake fluid when changing 1,20 litres
Brake fluid specification from 2006 VW 501 14-B 000 750-
Brake fluid specification up to 2005 DOT 4
Brake fluid change interval every 2 years
What on earth is that VW spec though and how on earth does that differ from the DOT specs.
I guess it's just their internal spec for it.
The 3C Passat and later models is running a slightly different fluid (EBC 440) it has from what I understand a different operating range (like a Super DOT4) this is required for the newer ABS systems.
