Info: 55mm Lowering on just springs
Hey,
Im going for a 55mm drop on supersport lowering springs.
does anyone know what the gen is for any extra things I need for a drop more then 40mm?
do i require shorted bumb stops?
thanks again :thumbup:
it'll be fine but you will probably wear your shocks out faster.
you'll probably also need to get your tracking sorted, the lower you go the worse it gets.
