Seat change
Can some one confirm that VW Golf mk 4 seats are a direct swap into 2002 Fabia
Also does the Golf steering wheel fit as well
The newer ones are fitted with the seat runners with the 4 spline bolts holding them in.
The MK4 golf seats have the 2, 13mm nuts at the front under the seat holding them in.
Check your seats and this will answer your question.
Im not to sure if the older ones are different or not.
Yes the steeting wheel will fit, you will have to get the propper airbag etc.
Im still on the lookout for an R32 wheels for mine.
no , is the answer
Just to confirm, all Fabia's seats are held in with the 4 Spline bolts?
yes
Keep it simple. Ha.
Yes , just looked and they are bolted in, so which golf seats fit, do I look for MK 5,R32 type.
Yep, anything out the MK5's will fit.
Thanks to you all :thumbup:
  • 3 months later...
Im possibly getting a set of E30 seats.
I can't help much with what will or will not fit..
I will however state - If you do with to sell your old seats. Please do give me a PM!
Cheers,
Rob.
