Fault code 17704 Help! Both Temp sensors replaced!!
I have been having problems with the above fault code, it eventually brings on the CEL and can also cause difficult starting when warm, started back in July, I changed the coolant bottle and it continued so changed the engine coolant sensor and today it came back again, easy to clear with vagcom but a bit of a PIA...now both sensors are brand new and it is still returning....anyone got any ideas ( it says 'error in mapped coolant system usually coolant sensor', next to the code) could it be the thermostat?
Anyone???????
  • 5 months later...
Daver, did you find the reason for the repeated display of this fault code?
I have a car in my family that is displaying the same symtoms, and I can't sus it out!.....:rotz:.
The code shown on VAGcom is 17704 P1296 - 35 - 10 Temperature sensor/thermostat.
Timpo.
i had problem recently with p1296 error code also think it shows up on some machines as 17074 i had the temp sender and thermostat replaced that sorted it but i think it was thermostat as when i got car back and turned heaters on i could tell the difference straight away with the hot air that was coming out
Same problems that i'm having and it's given the temp gauge a mind of it's own. Does anyone have a part number for a thermostat? and price? Much appreciated :thumbup:
Regarding the thermostat there are a few alternatives (engine code dependent), so I need to know your engine code + year of car (just to be sure).
The 'o' ring is a common part across the range :-
Part No: 038 121 119 B (Dia 50mm x 4mm) and is about £1.25 + vat
Peter
