So what triggers the interior light to come on ??
53 Plate Fabia Vrs.
When you open the drivers door Etc, (Without unlocking- Car already unlocked Etc) What triggers the interior light ??
There does not appear to be a Door switches !!
Reason i ask is !!!!
My Drivers door does not always trigger the light to come on :rolleyes: But all the other doors do Consistently :confused:.
Dean
switch inside the door latch tells the convenience module to put the light on i would imagine
So it would appear then that mine is pooped & on it's way out, As it works intermitently !!!
If that is where the switch is located, I think i'll leave it be :rolleyes:, Sounds like far to much hassle for a bit of illumination .. It still works when you pop the ignition key out ..
Dean
