Clutch failure - 2.0L TDi
2006 - 2.0 TDi elegance only 62000km on the clock, not driven hard and the clutch has failed. Think this is a hydralic clutch, pedal went straight to the floor. Left me stranded in the middle of no-where..............Anyone else have this problem??! :mad:
Its usually the dual mass flywheel that goes and does the clutch with it.
Let us know what the verdict is when you find out.
Good luck with it :thumbup:
Quite a frequent occurrence on the MK 1, especially in the cold weather. You can pull the pedal up by hand and carry on until the next time it happens. A new master cylinder usually sorts out this particular clutch problem.
Had exactly that problem on my 52 plate Golf. I think there was a duff master cylinder period, because the same problem has been posted on here before. The local VW agent did mine under warranty and it took about an hour.
I doubt it will be a clutch issue of the pedal has hit the floor.
They can suffer from the plastic rod breaking in between the mater cylinder body and the pedal. It could also be a leak on the clutch or brake system of course.
