mk2 vrs mp3 streamline!!!! help >:(
ive just got a 07 vrs i need help with my head unit. is it realy any use?? i want to use my ipod but im told i have to sack the multichanger in the boot.:confused: i dont realy have a problem with this althogh i thought id be able to use both. I went to the dealer today thinking i could get a cable that i could run from the back of the headunit :mad: no such luck turns out i need to buy sum sorta box that goes in my glove box and then this will allow me to connect my ipod the price of this is £99.00 then i have to pay to get it fitted:eek: apparently this is the only way to do it and it will display andallow me to work my ipod from the head unit!!! before i cough up this money can any1 tell me is this the only and cheapest way:confused: ny help on this would be much appreciated:thumbup:
Do you have the jumbo box?
IF so, simply use the aux in point, cost £4 max. Otherwise, yes this is the option you'll need.
Before you consider buying the lead, check how much 'control' it actually gives over the ipod. From what I can gather it is fairly limited, so I doubt you'll be able to make a lot of the selections which you can on the ipod itself.
The kit you've been offered for £99 will be the OEM version of the Denison Ice Link.
no gadgetman i dont have the jumbo box so looks like im gona have to get the 99.00 device from the dealer :( thanx 4 your reply:D
VRStu do these devices work ok?? The manager at my local dealer had 1 in his vrs and said it wasnt much use. im not to fussed about it displaying on the headunit i just want my ipod in my car and would be happy if i can select my tunes through the ipod itself!! do you no if i have to sacrifice my 6 disc changer??
Yes you would loose it.
  • 4 weeks later...
I'm no expert, but I think that if you fitted a Dension Gateway with one of these:
Dension: Accessories
then you could retain your cd changer. Not sure how it would work control-wise. Presumably pressing CD/AUX would cycle between the units, but don't quote me on that.
