Sphere Sub Box Polished Up
Well this was an interesting challenge!
My brother bought a sub box for his home stereo and it needed a little TLC. I wasn't Sure on how hard it was going to be as I wasn't sure what kind of finish it had but this shows the layers used to make it.
main.php?g2_view=core.DownloadItem&g2_itemId=1291
Unfortunately I forgot to take a good before overall pic but here goes.
The Sphere was first wiped down with Megs NXT detailer and eurow towels and then clayed using the NXT to lube it.
I then started on the polishing pad using 3.02 and made little difference to any of the marks so slowly worked to a more aggressive cut till I settled on using the cutting pad with 85rd as it was offering 90% correction and I wasn't sure how much I had to play with so didnt want to go much more aggressive.
I then worked back to using the 3.02 on a polishing pad, then I used some AG SRP to try and fill some of the remaining marks which had not been removed because I like the finish offered from SRP when machine applied. I then applied WMF on a finishing aswell for the final work, i will be waxing probably with Vics concours when i can afford to get some.
my only dislike was upclose under the led light it appeared to have a white haze in the colour but is difficult to notice in normal conditions.
My Products To Use where;
Sonus Green Clay
Sonus SFX 1, 2, 3 pads
Menz 85rd and 85rb3.02
AG SRP
CG WMF
CG Speed Wipe
And it will be waxed once i decide what to use on it.
So The before pics i have;
main.php?g2_view=core.DownloadItem&g2_itemId=1268
main.php?g2_view=core.DownloadItem&g2_itemId=1272
Part Way through
main.php?g2_view=core.DownloadItem&g2_itemId=1275&g2_serialNumber=1
main.php?g2_view=core.DownloadItem&g2_itemId=1277
main.php?g2_view=core.DownloadItem&g2_itemId=1280
Finished
main.php?g2_view=core.DownloadItem&g2_itemId=1283&g2_serialNumber=1
main.php?g2_view=core.DownloadItem&g2_itemId=1285
main.php?g2_view=core.DownloadItem&g2_itemId=1288
thanks for looking and CC all welcome
