Second AMP
Hi all,
i want to put another amp to my skoda octavia vrs. I already have one amp for the sub and want to add another for front door speakers. I'd like to avoid dragging another cable from battery to the amp, could I use the same cable and just connect second amp to it?Cables are for higher wattage so there is no problem with that, and I would also use the same remote cable, any suggestions???
Thanks Mark
What guage is the power cable?
if you can work it out this thread will help.
HERE
its a basic calculator to work out length vs guage vs amp's (measurement not how many). i would always use 4guage minimum anyway having seen some pretty scary stuff before with lower guage cables used.
i am not sure, but the cable is around 5 to 6 mm thick if that helps
