VAG-COM in and around Lancashire?
Hi,
Does anyone have VAG-COM in or around the following areas for a 2000 'W' Fabia 1.4 16v:
Preston, Blackburn, Darwen, Bolton, Ramsbottom, Accrington, Manchester, Burnley, Chorley, Colne.
Need someone to try and access the engine to try and find out what is happening with this bloody car of mine, symonevens tried and had no look anyone else willing?
Also is anyone willing to meet up from either Liverpool or Blackpool areas?
Cheers,
Chris
Chris - can have a look on Sat when I see you if you want, if there's still an issue?
Steve
The engine management light is off, but the garage says the controller unit (think thats the one) keeps reseting its self. You can have a look by all means.
No probs, can run a scan and give a copy of the results - might hopefully give you some more info and/or lines of enquiry :)
Steve
Can i just piggy back on this if the op doesn't mind
a mate of mine needs help with VAG-COM as well
Heres his post from the local club
'think I've got a dodgy ABS sensor on the old Skoda (99 Octavia). Does anyone have a VAG COM so I can plug it in and pull the codes. Obviously, since the car is worth buttons I'll be a bit miffed if it's a major component, so if possible I'd like to get the work done cheapish.'
If poss pm me and ill pas him the details/ ask him to contact your self
