HELP- SPEC Flywheel problem
Help coleagues,
Today we started to change the standart Skoda Flywheel.
But there is a problem.
(I dont know how to say it in English)
The 3 of the 18 rays are lower than others on the pressure plate!
LOOK?
Is there a problem?
There is the problem with the 2,3 rays on the presure plate?
Please-I nead an advice.
Or tommorow i will fit it that way.
My old flywheels is OUT OF ORDER :mad:
you mean the clutch cover springs, i would strip it down again and make sure everything is flat/true ,
the 3 "rays" as you call them should be level with the rest, they could have been damaged in transit, or when you have tightened the cover down , it was done unevenly , which has caused the distortion
it should be ok to use like that , but there is no gaurantee it wont fail at a later date
Id agree, were all of the cover plate bolts tightened down evenly?
Yes, they are.
If i will fit it that way-would it be a problem?
