1.4 16v Fabia Fault read outs
Hi,
I have a slight problem with my car if anyone can shed some light as to how this has happened, or if possible get/already have the correct coding for the Engine Control Module my car that would be good to?
The car in question is a MY2000 Fabia 1.4 16v Comfort. Thanks to Wardy for getting these results for me.
Chris - Fabia1 1.4 16v.txt
Log-CHRIS-TMBND46Y4Y3041790-138110km-85817mi.txt
Edited by chrisw880
Try 00071. Does your air conditioning work? Some of these did come incorrectly coded from the factory.
Air Con has no known faults - might require a recharge tho
Is that to supersede "Software: 00031" in the coding for '01 Engine' ?
Steve
Yes, go into 01, the 07 and then change the coding.
Re-coded the ECU, but the fault stating its incorrectly coded is still on.
Managed 35miles before EML came back on.
EDIT: EML has gone off this afternoon.
Edited by chrisw880
Yes, you still need to work out the cause for this error, which is still present:
18020 - Engine Control Module Incorrectly Coded
P1612 - 35-00 - -
Steve
Looked on google but all I can see is other people complaining about the same fault and that 00071 has worked for them.
