Octavia 1 VRS codes.
Hi all.
Well, only had the car a couple of days and already it looks as though I'm going to have to sort out a few issues. The check engine light came on so JohnRS kindly plugged is Vagcom in for me. This is the result...
Address 01: Engine Labels: 06A-906-032-AJQ.lbl
Part No: 06A 906 032 HN
Component: RS-TUNING LTD G 0007
Coding: 11500
Shop #: WSC 14389
TMBER41U338674430 SKZ7Z0B1497186
4 Faults Found:
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-10 - - - Intermittent
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
Readiness: 0000 1000
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 31480 000 00000
3 Faults Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
008 - Implausible Signal - Intermittent
012 - Electrical Fault in Circuit - Intermittent
01314 - Engine Control Module
013 - Check DTC Memory
Address 08: Auto HVAC Labels: 1Ux-907-044.lbl
Part No: 1U1 907 044 A
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 31480
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601
Component: 0F AIRBAG VW51 0004
Coding: 12358
Shop #: WSC 31480
Address 17: Instruments Labels: 1U0-920-xxx-17.lbl
Part No: 1U0 920 911 C
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 19412
Shop #: WSC 31480
2 Faults Found:
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
2 Faults Found:
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 3Y Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 31480
Part No: 1U6959802D
Component: 3Y Tõrsteuer.FS KLO 0004
Part No: 1U6959801D
Component: 3Y Tõrsteuer.BF KLO 0004
Part No: 1U0959811D
Component: 3Y Tõrsteuer.HL KLO 0004
Part No: 1U0959812D
Component: 3Y Tõrsteuer.HR KLO 0004
End ---------------------------------------------------------------------
Some of it is self explanatory, but obviously I'd like the experts opinions if they'd be so kind.
Thanks in advance.
Clear all the codes and see which ones return would be a start. On the face of it, it looks like no 1 probe and the air mass meter are faulty, a non original radio is installed and the CAN communications for the comfort system are using one of two wires.
Thanks matey. I've sent the results over to MB Motorsport to have a look at and I'm going to leave it with him on Thursday or Friday to look it over for me. Michael seams pretty confident that, from the results at least, it's minor glitches that can be easily sorted. Although it's puzzling how they have suddenly come on, all together, once I've got the car home. :confused:
Anyway, has anybody got more input on them? The one that particularly concerns me is..
I've seen that one a couple of times. On both occasions it was shortly after a cam belt change, both times it was put on a tooth out.
Ross Tech have a fairly comprehensive list of codes here:
Category:Fault Codes - Ross-Tech Wiki
Cam belt was done about 30k ago though. Unless it has jumped a tooth, but if the timing was out I'd expect it to run like a bag of spanners. I'll make sure that the timing is checked while it's in though.
Just got it back from the garage. New O2 sensor and timing was a tooth out. All better now and feels even better to drive! Had it out for an hour of playing, used a silly amount of Vpower and the light has stayed off.
Touch wood, it will be the the same when I go out in the morning.
Good to hear its sorted, hope it didn't cost too much to get sorted, Michael & Kev know their stuff and are reasonably priced :thumbup:
More than I wanted to pay after only owning it for a few days. :lol:
Yeah, happy with Michaels work matey. Thanks for the recommendation. :thumbup:
Glad you've got it sorted. If you got the car from a dealer you may be able to get a contribution from them after the repair. You could have got them to fix it and pay for it from the start.
Looking at your log, the bit that says:
usually says:
Component: 1.8L R4/5VT 0002
Has it been remapped?
usually says:
Yeh, it's Quintens old car. Hopefully that bit will be saying Jabbasport again soon. :thumbup:
I bought it privately matey. Just one of those things I suppose. It's had both me and MB Motorsports puzzled though as it really didn't drive as if the timing was a tooth out.
MB are Jabba agents, but only offer generic maps, you'll want a custom if you want it back to peak power i assume. It seemed to run ok didn't it. If it runs better now its a bonus!!
