How to check RNS510 Map version?
I know this question has been answered before - but my searching skills are obviously lacking!
How can I check what version of Maps are currently installed on my RNS510?
Ta
To check which version you have loaded you can press and hold the setup button as the RNS boots and the service menu will appear after around 20 seconds
To force a reboot of the Columbus you can hold the three top buttons < > and i
Sometimes the Columbus is booted up and running before you turn the ignition on.
Humm - I think I'm doing something wrong.
If I press and hold "Setup" and then switch the RNS510 on, it eventually get's to a menu where I can select:
AM
FM
DAB
As I press each of those it'll tell me signal strength.
I know the setup screens you all talk about - as I've been in them before.
However I just cannot seem to get back in to see if my V4 maps update has taken or not.
Use the < > i buttons at the same time.
As soon as skoda auto navigation appears, press and hold setup. Do not let go for at least 20 seconds.
Release button and a diagnostic menu should appear.
If the menu does not, then it could be the version of firmware on your unit (especially if its a B unit) might not have the option enabled by default.
AM
FM
DAB
Have these things got DAB on them too???
