P0172 and P1141 Fault Codes
I have now managed to read the fault codes from my father's 02 Fabia 1.4 MPi. I have a P0172 System too rich (Bank 1) and P1141 Cross check range faults.
I understand that these could be due to the MAP sensor. Is this right or are there other things I should be looking at? Where is the MAP sensor on this car?
Thanks in advance
MAP on the inlet manifold
16556/P0172 - System Too Rich, Bank 1
Possible Symptoms
Irregular behaviour
Possible Causes
Fuel system
Excessive fuel pressure
Leaking or contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Air leaks after the MAF
Vacuum leaks
Improper seated engine oil dipstick
Stuck EGR valve
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near HO2Ss.
Retrieved from "http://wiki.ross-tech.com/index.php/16556/P0172"
17549/P1141/004417 - Load Calculation Cross Check: Implausible Value
Possible Causes
Mass Air Flow Sensor (G70) OR Manifold Pressure Sensor (G71) faulty
Vacuum Lines faulty
Possible Solutions
Check Mass Air Flow Sensor (G70) OR Manifold Pressure Sensor (G71)
Check Vacuum Lines
Check Engine Operating Conditions => Meas. Blocks
Special Notes
Uwe: I think this code is set when the airflow being measured (or otherwise calculated) by the ECU doesn't make sense given other operating parameters such as RPM and throttle opening, manifold pressure, etc.
