Bought used Fabia - 2 Faults: 16500 and 16725
Few days ago I've become an owner of used Fabia 2003, 1.4 MPI, 71000km.
It drives fine, but when idle it's a bit "pulsating" if I can put it that way. rpm arrow is not steady and I would say it moves from 600-900 rpm.
So, I've decided to connect to VAG-COM and this is what I got:
Address 01: Engine
2 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
16725 - Camshaft Position Sensor (G40): Implausible Signal
P0341 - 35-10 - - - Intermittent
Address 03: ABS Brakes
1 Fault Found:
01314 - Engine Control Module
79-10 - Please Check Fault Codes - Intermittent
So, changing a coolant sensor is one action I would say (anyone to point me where it is exactly?), but what about this CPS ? Any comment is very appreciate.
Thanks,
+adnan
The CPS fault will propably be the biggest influence on your tickover flucuation. Not to sure where the temp sensor on the 1.4 is. But look around all the coolent pipes for anything with an electrical connection and you'll probably find it easily.
Thanks "auroan" for quick reply.
Yes, I would agree the same that fixing CPS fault will remove fluctuations. Problem is that I have to investigate weather this is a problem with the actual sensor or with timing (as per: ross-tech).
Any idea on how to do this? Where would this sensor be located?
* Update *
I've decided yesterday to change coolant temp sensor but prior doing that I wanted to clear error codes and see if they will popup again. Guess what, they didn't! I did a nice 20 min drive, and than one more 20 min drive but nothing. No errors. That sounds great! But,....
But this morning my car was struggling to start.
Did anyone had experience when you turn the key, absolutely nothing change in car behaviour, not even a 'tick'? But after 3-4 tries car start like it's suppose too and drive is just fine (except rpm fluctations on idle that still exists).
I would assume battery is fine. I cannot claim that 100% but from my previous car experience, if you have problems with battery you won't start after 5 tries.
So, that leaves us with .... ?
Thanks guys for all the help!
p.s. I've just realized I'm writing in a wrong forum section :( My apologies for that..
Edited by cadnan
inform audience that I'm writing in wrong forum section
* update *
I was looking on this forum for posts on the same starting problem with fabia, and found out that one solution could be changing coolant temp. sensor. Since, I've had previously a fault registered by VAG-COM on the same sensor, I've decided to go for a change.
I've bought it during the day yesterday, but didn't want to change it immediately since car was starting without any problems. I was waiting for a moment when it's not going to start, and that is in the morning.
So, this morning at 06:00 AM I went to my car on parking and of course it doesn't want to start. Once, twice, nothing..
Then I change the sensor, and try again, ... nothing once, nothing twice, third time it starts.. I turn it off, try again, nothing, nothing, nothing, start..
Then I decide to go for a drive just to see if sensor is actually working. After 13km on highway, I went back to my parking, car has it's working temperature, arrow is pointing fine, I turn off the car, start again nothing, nothing, nothing, start!
At 07:25 I went again (but this time to actually go for a job) and it start first time.
I will watch its behaviour for the next three days when I'm away for small holiday, and give you more updates on Monday.
In the mean time, anyone have any kind of proposal what to look for?
Can someone tell me how is car behaving when engine starter is getting worse? I have a small suspicion that he might be a problem, but still it doesn't sound like that. When car doesn't want to start it's just like dead, not a single 'klik', but when it "decide" to start, it's very normal start.
Have you cleared the error codes and if so did they come back?
I had a CPS go on an old Omega, never had the starting issue you described but it did cause the eninge to stop for a split second while driving the almost immediatley restart. Eventually it just stopped and wouldnt start. Not sure how easy a job it is to change CPS on a fabia but thats where i would start
I've cleared error codes last week to see if they will come back, but they never appeared again and I'm like doing vag-com diagnostic every day. Will do today also. Camshaft Position Sensor is reachable from front bottom of engine and I guess it shouldn't be a problem to change it, but I don't know is it possible that bad values from this sensor can stop me from turning engine on?
Anyhow, I didn't notice some problems during driving, specially not the stop of engine! Only this starting and unstable idle rpm.
So when the car fails to start, you stick the key in and turn to the cranking postion, you get the lights on the dash but nothing actually happens with regards to the engine? No turning over, nothing? If so then i'd say sticky starter motor myself. Can you see the starter motor when looking under the bonnet? If so the next time it won't start, try giving the starter motor a tap. If it starts straight away after that then at least you know that's the issue.
Exactly, it looks like ECU doesn't give a **** that you want to start your engine! And once it decide to let you go with it, you can fire without any problems. Lights on dash are completely normal.
Anyhow, I've ordered CPS and we will see how will that go. I would also do another diagnostic today to check if some fault pop up.
Thanks a lot guys, really great community here! :thumbup:
* update *
I'm back from a 900km trip to Göteborg and back with some driving in the city itself. Nice place to go for a visit (and I guess for living too!). Liked very much.
What I liked more is that my Fabia was a very good girl (is it common to consider it a girl? :) )
'She' was starting the engine without any problems at any time I needed. When I get back from the trip, I've done diagnostic and there were nothing. Wow.. I was satisfied, until this morning :(
Nope, my Fabia doesn't like the mornings. Same problem, only after four five tries it will start.
Anyway, I've ordered CPS and will see how will that go, but wanted to write this down for the future problem researchers.
In the meantime, anyone have a pointer to a tutorial on changing CPS?
Thanks!
Hi there everybody, I myself bought a used fabia! I'm loving it!
it's 2001 skoda fabia, 1.4 MPI, and only 47 thousand kilometers on it!!
I think I got myself a good deal, but the car needs some minor bodywork, and the electricity of it isn't all that great!
I went to a skoda authorized service partner.. suffice to say,they asked for an insane amount of money after I had it inspected, and they didn't point out half the things I know the car needs!
so I'm thinking I wanna start doing things myself!
now this is my 2nd car, and it's pretty high tech considering the previous car I owned was a peugeot 504!! loved my peugeot though!
my questions for you are:
1-where can I get the service manual for it? I've basically been searching all day, found a couple, one in Czech and one in russian.. I speak neither!
2-where can I get the software needed to be installed on the computer that is connected to the car via the USB to VGA-COM cable?
3-not that it might complicate things at all, but I'm in africa, so the only place you'd recommend that I'd be able to go to would be be online! lol
thanx in advance!
Hi lonewolfmiles and welcome to briskoda.net
As you can notice I'm also new here but that doesn't stop us from helping out each other.
First, congratulations on your new Fabia! I hope you will be able to drive it for many more kilometres without any troubles.
Regarding your questions, let me try to assist you:
1. I didn't manage also to find a good service/repair manual online, but I'm considering to get a Haynes Skoda Fabia manual. Try searching for it on amazon!
2. I am using a shareware version 409.1 of VAG-COM from ross-tech.com and I got a cable from local ebay site here in Sweden. Maybe you should try and go to global.ebay.com and get sellers which are sending items to africa. I really don't have experience with this.
