Adjustable top mounts?
OK i'm looking at changing my suspension set up and wondered if it's worth fitting a set of adjustable top mounts mainly for track sessions.
Has anyone fitted these and how easy are they to adjust from one setting to another.
KW ones are favourite at the mo.:thumbup:
No idea about adjustable top mounts, but you can get cam bolts that let you adjust camber through the damper to hub carrier mounting.
Eibach do some too
Bit cheaper than KW , but KW say they only fit V3`s
The bolts we have looked in to , and I was told they dont fit the Golf 4 chassis
Jay
If you PM me I will call you if I only had your number
Sarah
Cheers. What I was told was that the cam bolts need the holes in the uprights opening, so you can't change back short of buying new uprights.
