Amp fitting and sub box?
Hi, firstly is it possible to run a amp of the standard head unit in a Fabia VRS, I appreciate it won't sound quite as good, but i hate the look of aftermarket head units.
Secondly, I am after a 10" sub box for the boot of course, but would prefer one that is built into the side rather than a square box. Would this need too custom made or can you buy one of the shelf?
TIA
Mike:thumbup:
The standard stereo doesn't have the pre-outs required. You can (I believe) use a cross over to generate these outputs.
As for the sub box you will need to custom make one.
HTH.
i got a custom made box that utilised the spare wheel cavity. I currently run an 11" focal sub in it sounds great
where did you get your custom spare wheel mounted sub enclosure from,ive got a sub box at mo but due to dog ruining seats, id like 1 to go there as dog guard would show sub box.thanks. steve
auto acoustics make 'stealth boxz' which go over the wheel arch as you asked. There pricey tho
Auto Acoustics StealthBoXz
TIA
Mike:thumbup:
From the HU youll need one of these it converts high level output from HU to RCA output
auto acoustics do a box or you can make your own easily enough with a bit of patience and research.
Check out Talk Audio Forums - Powered by vBulletin and look around theyre very helpful and knowledgable about car audio.
