reducing pic file size!!
this is probably a straight forward action to most...
i have taken pics of my fabia vrs and the file sizes are between 2.5 and 3.5mb.
is there a way i can reduce these jpg files to upload here? or do i need to change settings on camera and retake them?
thanks in advance....................
google "mihov image resizer" - I use it for anything like that. :) handy little free app.
thanks.... will check it out now
Or if you already have M$ Powerpoint , then insert your picture (s) and save as JPEG interchangebale format. Makes a 3Mb file around 100k.
If you are using XP there is a power tool that I use available from MS.
You right click on the picture(s) and click resize and you can then resize the images to the size you want.
Another one I use on my Vista pc is VSO image resiszer which works almost identically to the MS one for XP.
Phil
And if you have microsoft office use Picture manager ;)
Thanks for all the replies...
Am usuing Mihov Image resizer which does the job nicely :thumbup:
And here's a dirty hack :)
Open in paint, select 'strech/skew' from the edit menu, stretch to something like 25% on both the X and Y axis - job done.
All other methods mentioned are better than this, but useful if you're in a hurry!
