Need info for 1.3 carb N/A tuning
hi every1 last time i was asking for a 1.8t 20v engine swap many didnt recommend this swap cause the engine is too wide to be fitted in a felicia bay , also i heard about a 1.4 16v 100hp from 6n polo but its a rare engine and its spare parts are very hard to find :mad:,by the way i couldnt find any1 on the web has performed this 1.4 swap !? . i decided to modify the 1.3 carb , any suggestions about new carb, throttle body, custom exhaust or lightweight parts ??? (97 felicia)
Em, I'd have thought a 97 LXi would be injection, not carb?
In some countries the Felicia was carb rather than injection. Not sure of the rationale, but I know a carbed Felicia in the UK wouldn't have been legal to sell. And oh yeah, "i" in the model number should indicate injection.
mine is a carbi, 1289, and the best thing to tune them is taking them to a dyno, now, you can swap the jikov and get a weber, slighty large 28/30 and it will run great (im watting to do the engine makeover to fit this one in) i've seen a couple of engines with 4 bike carbs jetted and tune for the 1.3 and it does give lots of torque.
going a little off spec with the valve clearance (increasing the clearance on the exhaust) give you a small boost in engine power in low rpm, dont change the muffler diameter, just get a bigger box and swap the middle for a straigh fiber one, if you increase the diameter is going to loose power
