Event mobile tyres
Has anyone used these guys?
Tyres Online | Mobile Car Tyre Fitting | Event Tyres
The prices seem very good and you can harass the fitter whilst he he doing the job.
One thing im not too sure about is
For the more knowledgeable car enthusiasts on here
Is the above quote correct????
used them numerous times - excellent service and no problems.
there not cheap!!! just looked n there website you can get the tyre much cheaper and the local garage shoulf fit them for a £10 :thumbup:
Think it depends on what your looking for at the time. recently bought some Michelin exalto pe2's. cheapest I could get the tyre was blackcircles for just under £100. Mtyres was a similar price. Event tyres was just over £100 fitted andf they come to you.
Used them twice now. No problems and very convenient.
Think so - when you get your tyres changed, all they'll usually do is fit the new tyre on the rim and balance it before fitting. They won't do anything with tracking unless you specifically ask them, or if they notice your tyre has worn peculiarly.
I've used Event before and would recommend them - submitted an online request on a Friday afternoon, they were on my driveway fitting the tyres the next morning...and while not the cheapest, I believe them to be very competitive for the service they offer.
Rob.
Event's comment seems logical to me - if the tracking's out, the old tyres will be worn unevenly. This is much easier to see with the wheel off, as you can then see the entire width of the tread straight-on. Changing a wheel wouldn't affect it, as it bolts straight and rigidly onto the hub. I suppose you could put a wheel on wonky if you weren't paying attention, but that would wobble as it rotated, which an entirely different problem.
As for quality / reliability, they've fitted well over half the tyres I've had since I got the car (5x Proxes T1-Rs, 6x Falken ZE912s from them; 2x Proxes T1-Rs bought from Blackcircles and fitted at the local garage needed rebalancing straight after, 4x P-Zero Neros bought from mytyres and fitted at Awesome worked out more expensive all-told) , and although I've occasionally thought I could get the work done better for less, I always end up going back to them! :)
Thanks to everyone for the replys
I will give them a try when i get my tyre money together
Myself and the wife have used them.Excellent service,will use them again when needed.
Used these a few months back for my vrs and missus' mini. Saved 10% buying 4 tyres.
They were spot on and balanced he the tyres afterwards. Cheapest I could find.
