rattling rad
Got the classic rattling rad. Can't be bothered replacing mounts right now but plenty of people have mentioned success with jamming pipe foam around the rad instead as a bodge fix.
Just had a bash at this myself but can't see an obvious place to wedge the foam. Does anyone have any pics they can provide or a detailed guide as to where they go?
Cheers,
iep
I have
This my method. But bear in mind my rattle is predominantly on this side.
I wrapped the lagging in gaffer tape then used a bit of double sided foam type stuff to hold it in place.
Could be a bit neater I guess but it serves the purpose for now.
HTH
i did mine from underneath the car,if you look at the rad from underneath you will see a thin cross member underneath it,all i did was wedge some padding inbetween the bottom of the rad & crossmember,i havent got any pic,s sorry! i should of taken some last week when i replaced my front wheel bearings!:)
