Fitting VRS front shocks to an L & K
Do they fit? Anyone done it before?
Any help appreciated :thumbup:
they will fit, and be firmer ride. Also if you are using the VRS springs this will lower your car approx 20-25mm, as the VRS sits lower.
Mark
Actually , I dont think they will fit
The vRS has the longer drop links.....(woits to be put right.....)
Sarah
Hi!
The vRS uses the same chassis as the TT, S3, Cupra etc, so the wishbones and arb are not the same as Octy L&K std chassis. They shocks might fit, but will probably not be a good match.
Order Koni FSD's from Sarah instead, or STR.T or Yellow if you are into lowering the car.
Olit
Sarah
They will fit but as you stated the drop links on the VRS are different(same as Audi TT , S3 and R32). This should not be an issue though as the LK drop link bolts from the wishbone to ARB (if not mistaken, as per golf set up) so the drop link mount on the VRS strut is redundant.
Oooh glad I am not going silly.....and thank you for your good words
Sarah
