Do I have the dreaded rear camber issue?
I've been reading all the issues that people have had with their unevenly worn rear tyres.
I checked mine yesterday and noticied the following tread depths:
NSR 3.5mm / 4.5mm / 2.0mm
OSR 3.0mm / 4.5mm / 2.0mm
measurements are taken from the outside shoulder (the edge of the tyre where there is still full contact with the ground) / centre / inside shoulder (i.e. both inside shoulders are 1.00mm to 1.5mm more worn than the outside.
Pressures are set to around 2.8 (bar I think) and are Dunlop Sport Maxx XL on 18" rims.
Car (TFSI) has done 22k miles, no towing and rarely heavily loaded and is on an 07 plate.
Should I get it checked or does this sound more like the tryes? Fronts appear evenly worn.
R
Seems a little odd that they're on 2.8 Bar, yet you've got such large shoulder wear compared to the centre of the treads (if I've read your measurements right).
40psi & still getting edge wear:confused:
You have done 22k miles on a single set of tyres. Who cares if they are wearing uneven ;)
Seems to me you have two issues:
  1. camber
  2. low tyre pressures. try 3 bar
  1. camber
Your kidding?
Without seeing the tyre it could be half a dozen problems - excessive -ve camber & excessive toe-in spring to mind.
Your kidding?
Yeah I thought that too. That's around 43 psi :eek:
I don't think tyre pressure is your problem here.
You do not need pressure that high, even loaded up.
If you are running the car loaded at all times like I do (works car - spares) then inner edge wear is an evil we have to put up with.
Empty you shouldnt be pushing more than 35psi.
