Alloy wheel offset help required!!
Hi im new to this site having just sold my peugeot 306 gti6 and just got a 54reg octavia vrs :D
The wheels and tyres on it are a bit kerbed and need 2 new tyres so ive been looking at some aftermarket alloy wheels
Ive found some wolfrace wheels which a lad had on is subaru impreza. I know they have the same pcd but it says the scooby offset is 42 to 50 and the octavia offset is 35 to 42
It also says the octavia wheel bore is 57.1 and the scooby bore is 56.1
Will these wheels fit or will they need spacers as i dont have a clue!!!
Any help will be greatly appreciated.
Dan :)
Have a read of this and it should help you out:
Wheel Offset Calculator
You will need a spigot ring to get from the 56.1 to 57.1 but nt sure they make them that small to be honest..........:o
If the scooby bore is less than the octy, it won't go on without being machined out.
Alot of aftermarket wheels tend too come with a 66mm centre bore and spigot rings too take3 it down too the required size. The offset may be a problem most Scooby wheels tend to be ET50 offset.
